Quickdraw GN to Blue Thunder
Re: Quickdraw GN to Blue Thunder
Inside left front fender, removing sheet metal:
Quickdraw GN - 1 (10).jpg (20.85 KiB) Viewed 16263 times
Left front fender, new ABS plastic temporarily attached:
Quickdraw GN - 1 (11).jpg (12.47 KiB) Viewed 16263 times
Quickdraw GN - 1 (12).jpg (17.56 KiB) Viewed 16263 times
Quickdraw GN - 1 (13).jpg (24.97 KiB) Viewed 16263 times
Left front fender, and front end progress:
Kaye if this resto on the body turns out like the Yankee f1,it's going to be superb. Is that a one off chassis? I've seen that chassis before but forgot the story behind it?
Emilio wrote:Is that a one off chassis? I've seen that chassis before but forgot the story behind it?
Emilio: The chassis is a Quickdraw Grand National, I think it's from 1992. They say on the internet that something like 50 examples of the chassis were produced. The chassis is very well built, I like all of the aluminum detail, particularly when it's polished.
big maestro
Post by big maestro »
Kaye, there were actually only around 25 produced. They made enough parts to build 50 though.
big maestro wrote:Kaye, there were actually only around 25 produced. They made enough parts to build 50 though.
big maestro:
Thank you for the info.
Front left fender restoration in progress showing re-assembled ABS plastic ' fender jigsaw puzzle pieces', fused to ABS plastic backing plates and strips (soldering iron heat source). I'm not skilled at this, I'm making it up as I go along.
Front end re-attached.
Great job Kaye.
Thank you CALracing!
Do you have the spoiler or do you have to fabricate it. geoff
CALracing wrote:Do you have the spoiler or do you have to fabricate it. geoff
I'm going to make a front spoiler for the body out of ABS plastic. I've been messing around a little bit this past weekend trying out some ideas.
I have the black plastic 'spoiler' that attaches to the front of chassis.
