Quickdraw GN to Blue Thunder
Earlier this year I was fortunate enough to add a Quickdraw GN to my 1/4 scale collection. The car, formerly owned by member PTModIT, is in good condition.
Work done so far includes a little bit of chassis cleaning and polishing. The ABS Thunderbird body that came with the car has been repaired many times with rivets, sheet metal, and shoe goo. My current work plan is to carefully remove the rivets, sheet metal and shoe goo, and to plastic weld new ABS material (using a soldering iron) into the cracked bodywork. Missing pieces of fender and front end will be cut from sheet ABS and 'let into' the body where needed.
If I can successfully repair the body I'll refinish it to resemble Mike Cook's Blue Thunder Bonneville salt flat car.
Here are a few pictures of current progress:
Re: Quickdraw GN to Blue Thunder
Front end:
- Attachments
- Quickdraw GN - 1.jpg (21.91 KiB) Viewed 26219 times
Rear bumper:
- Attachments
- Quickdraw GN - 1 (1).jpg (17.69 KiB) Viewed 26219 times
Rear bumper, new ABS plastic temporarily attached:
- Attachments
- Quickdraw GN - 1 (2).jpg (11.99 KiB) Viewed 26219 times
Inside right front fender:
- Attachments
- Quickdraw GN - 1 (3).jpg (15.5 KiB) Viewed 26219 times
- Attachments
- Quickdraw GN - 1 (4).jpg (17.13 KiB) Viewed 26219 times
Chassis:
- Attachments
- Quickdraw GN - 1 (5).jpg (16.64 KiB) Viewed 26219 times
Chassis:
- Attachments
- Quickdraw GN - 1 (6).jpg (21.54 KiB) Viewed 26219 times
Blue Thunder:
- Attachments
- Quickdraw GN - 1 (7).jpg (15.09 KiB) Viewed 26219 times
big maestro
Kaye, if you need any of the aluminum parts on the chassis let me know. I have a large supply of parts for that car.
Big Maestro: Thank you very much, this is good to know. I'm very keen to maintain the originality of the chassis.big maestro wrote:Kaye, if you need any of the aluminum parts on the chassis let me know. I have a large supply of parts for that car.
Inside right front fender, new ABS plastic temporarily attached:
- Attachments
- Quickdraw GN - 1 (8).jpg (17 KiB) Viewed 26202 times
Inside front end of body; plenty of scope for restoration!
- Attachments
- Quickdraw GN - 1 (9).jpg (18.01 KiB) Viewed 26202 times
nice project and a very rare car. Congrats!
Thanks Mike.Mike Casey wrote:nice project and a very rare car. Congrats!
