Mold construction question!!
Re: Mold construction question!!
Funny thing is that the sand castings cost me more then the investment castings. So another words, the skellenger center section is cheaper to cast then the PBS!!!
- stoneyberk
I have seen a few quickchange rearends in nostalgia dragsters... Bun never in a door car...
Well guys i've been doing alot of research on various types of casting process and have come to the conclusion that i may attempt to try the green sand casting form...Rather than needing a middle man.. '' Foundry '' I will attempt to build my own foundry... I've seen many types that may work quite well for this application.. I'm not set on what type i may go with yet but i thought i would post a few shots of some home built foundry's..
I'm willing to bet i can purchase all the needed material and build this for around $400.00 I would assume a small water heater would run around $150.00 or so... Or perhaps the propane type set-up??
Sand Casting Video;;
http://www.metalcastingzone.com/sand-ca ... nd-casting
Interesting Metal Casting Site;;
- 10.jpg (44.39 KiB) Viewed 4172 times
- 17.jpg (29.54 KiB) Viewed 4175 times
- 16.jpg (20.76 KiB) Viewed 4175 times
- n_a.jpg9.jpg (41.22 KiB) Viewed 4175 times
- n_a.jpg2.jpg (20.99 KiB) Viewed 4175 times
- n_a.jpg3.jpg (22.13 KiB) Viewed 4175 times
Last edited by stoneyberk on September 25th, 2009, 8:34 am, edited 1 time in total.
- stoneyberk
More
- 11.jpg (32.37 KiB) Viewed 4176 times
- n_a.jpg6.jpg (27.17 KiB) Viewed 4176 times
- n_a.jpg7.jpg (19.66 KiB) Viewed 4176 times
- n_a.jpg8.jpg (21.32 KiB) Viewed 4176 times
- n_a.jpg (25.74 KiB) Viewed 4176 times
- 14.jpg (30.97 KiB) Viewed 4176 times
you may want to think twice about that. John foster tried this and it sucked. The cost for cast parts really is not that much if you go to a foundry. You would spend less then what you stated on a hand full of them.
- stoneyberk
Moulding Bench
- Moulding Bench.jpg (39.95 KiB) Viewed 4172 times
- stoneyberk
I'll look into the foundry prices first mike... Perhaps john fosters set up wasn't built correctly... I've seen many nice looking casting done this way...
Take a look... You will need to join to view the pics..
http://groups.yahoo.com/group/castinghobby/
John bought all the right stuff but he was trying to do investment casting and thats a pretty tricky method to try to do at home. I am sure it can be done, but its not as easy as getting it right the first time. I think its like starting a new hobby. If you got the time and interest, then definately worth doing.
- stoneyberk
yeah i suppose the investment casting would be more complicated... trust me mike... I will do many test runs on this well before i actually attempt to cast my rear end... As i mentioned before.. I think the only issue i will have is the 4-link bracket location... So what I'm thinking is.. Once i pour a few of them i will grind the brackets off one casting and cast it as it is.. No brackets... Then i will mend them brackets back together then cast them,,, Then i can just place the plain rear end in the sand,, Then the cast brackets any where i want then... I mean i don't know if anyone would purchase a cast rear end from me or not.. But it's a piece of mind knowing i can cast it with the brackets in the correct location to line up with there chassis/frame rails.. I could do this with any of the needed brackets...
I also have a rear end from a lawn boy self-propelled mower i may cast...
Well after a ton of research i have made my mind up on the type of system I'm going to purchase.. It's refereed to as a Cowboy Furnace... It runs by a means of propane.. It runs $380.00 Then i will purchase a Large Steel Crucible that holds up to..15 LBS of aluminum,, @ $65.00 So I'm well within my means of around $500.00 to start... I will then purchase more PetroBond Sand / Parting Dust / Aluminum / Etc... I will build a few flask as well...
I'm going to give this system a shot,, If I'm not happy with the results i will then contact a few foundrys..
- Model S Kit $380.00.jpg (106.75 KiB) Viewed 4159 times
- cut away view.jpg (5.39 KiB) Viewed 4159 times
