1/4 Scale Pacesetter Funny Car
Post by jimmydelta »
Hi:
Someone has or knows where I can get the center hub for this clutch (Pacesetter Funny Car) or the complete system, its cost does not matter because I have already bought two, one from a chainsaw and the other from a trimmer and neither worked for me.
anytimerc
Re: 1/4 Scale Pacesetter Funny Car
Post by anytimerc »
All should that matter is the thread hole and clutch diameter. I found this?https://www.ebay.com/itm/265411143346?h ... Swb1RhLhvD
https://www.ebay.com/itm/224536791306?h ... Sw9OBg8ZY8
Hi:
That is the problem I have, that when I buy them the thread does not match.I have a collection to open a hardware store.It is the only thing that has held me to finish it.Thank you for your help.
James
anytimerc
Post by anytimerc »
The Poulan looked the same. You may have to replace the jackshaft to what is more current now?
You know where I can get a trans. shaft for this model?
anytimerc
Post by anytimerc »
Looks like 3/8" or 1/2" jackshaft. Cut to length add a couple flat spots for the setscrews and thread the end for a new clutch kit. Without really looking at it may require more work? But it would be well worth it.
I already found it. Thanks
