1/4 scale bodies
1/4 scale bodies
Hi all. Looking for 1/4 scale bodies that can be used for dirt oval racing as Australian Super Sedan style, or in late model class. They will have to fit onto a 1/5 Baja or SCT chassis, wheelbase is 570mm. Used is OK provided no cracks or damage. For freight purposes, I would like to purchase several from the same person if possible as the freight is calculated on weight, not size. (means only one freight cost). Photos would be appreciated of any you may have. Thanks in advance.
roofchopper
Re: 1/4 scale bodies
hi mate, dennis from face book with the 1/4 scale willys coupe, I have my first mould which I can do some shells for you, also I do a kit so you can stretch the Baja chassis to fit the wb of the coupe, I don't think theres many 1/4 scale shells with the Baja wb,
