Pro Stock
Re: Pro Stock
Now, back to the ProStock... what engine will you be using? When do you forsee the completion date?
Re: Pro Stock - Wheelie Bars
Rain - rain - rain all day again for me... (6-days straight!!!!) . I started the wheelie bars using Stoneberk's Baretta videos and photos I have from NHRA events of various Pro Stockers. The tires might be a bit larger than 1/4 scale but they look real good on the car. I will update once the bars are finished, powder coated and installed.
- Pro Stock Wheelie Bar 001.jpg (108.31 KiB) Viewed 8354 times
- Wheelie Bar - Boottom 2
- Pro Stock Wheelie Bar 002.jpg (116.93 KiB) Viewed 8354 times
- stoneyberk
Re: Pro Stock
Yes that wheelie bar design looks very familiar... The tires do look a tad big... But then again mine are to as well... Actually I'm going to use steel wheel collars on mine once i get around to looking for some that will work.. I will most likely just weld a piece of 3/16'' steel tube to the inside of it so i rotates well on the axle...
There looking good so far!!
grumpys toy
Re: Pro Stock
where did you get the body and scoop from? awesome looking car
Re: Pro Stock
Slight Progress Report: Adjustable top tubes on the wheelie bars are done. I hope to have them mounted on the car this weekend. Too bad for the Chi-Town Hustler.
- IMG_2367.JPG (114.57 KiB) Viewed 8252 times
- wb
- IMG_2366.JPG (120.71 KiB) Viewed 8252 times
Re: Pro Stock
Wheelie bars are done. It's now time for the engine and clutch mock up.
- Bars.
- IMG_2371.JPG (143.86 KiB) Viewed 8181 times
- Bars
- IMG_2370.JPG (156.24 KiB) Viewed 8181 times
Re: Pro Stock
nice!!! can we have a few pics of how you mounted them to the car please.
thanks
thanks
Re: Pro Stock
I tried to take a photo, but my camera (or photographer) is not too good at close ups. There's not a lot of room back there to get the camera in a good angle either.
I mounted the lower and upper links of the wheelie bars to the left and right side, rear axle bearing blocks. If there was an axle tube on the skellenger style rear, I would have mounted them there.
The bearing blocks rotate are attached to the frame with a four link, so the bars work fine.
- Bars Close Up 003.jpg (89.78 KiB) Viewed 8155 times
Re: Pro Stock
car is looking great!!!!!
Re: Pro Stock
I took a photo of the wheelie bar attachments from a front angle and it came out just fine. I'm not sure what the heck was going on with the previous photo - unless I had too many visits with my old buddy Weiser. I left each side a little long in the front, just in case I needed to mount something to them in the future. If the extensions aren't needed, I'll just chop them off and touch up the powder coating. I plan to mount the engine low and to the rear. The drive shaft isn't going to be too long at all. Stay tuned.
- Wheelie bars attached to QUARTER MORTAR brand rear end.
- Tires 006.jpg (116.39 KiB) Viewed 8128 times
- stoneyberk
Re: Pro Stock
Yaa think?c103110 wrote: I had too many visits with my old buddy Weiser..
Is this not the 4-link brackets rather than the wheelie bar brackets?
Re: Pro Stock
A brilliant observation! What exactly gave it away?
- stoneyberk
Re: Pro Stock
I assume the wheelie bars are mounted on the rear of the bearing block.. After all,, there not quite visible in that shot!
Re: Pro Stock - Engine and Clutch first mock up.
Engine and clutch mock up. The engine fits nice, and I'll soon make an aluminum mount.
- Engine Mock Up 002.jpg (122.95 KiB) Viewed 8390 times
- Engine Mock Up 003.jpg (134.91 KiB) Viewed 8390 times
