Raco Shock O rings ????
Venomusss
Post by Venomusss »
Are both rubber seals able to be replaced on the Raco shocks?
One is an easy to remove O ring, but the other seems to be seated in the the brass fitting in the end of the shock. I don't want to damage it by removing it unless it can be replaced.
Any help on this would be appreciated. Thanks, Chris
Domb1972
Re: Raco Shock O rings ????
Post by Domb1972 »
Great question, inquiring minds want to know. I need to rebuild mine also .
Thanks Dom
cryo-tek
Post by cryo-tek »
I got mine at the local Ace Hardware store. You could also get them at McMaster-Carr.
Venomusss
Post by Venomusss »
cryo-tek wrote:I got mine at the local Ace Hardware store. You could also get them at McMaster-Carr.
How do you get out the rubber seal on the outside of the brass fitting? It looks like it is under a metal ring that is compressed into the brass end.
The O - ring on the threaded side comes off easy.
