Thanks,
-Ted
Thank you so much Cryo-tek that is an unbelievable amount of help. How many rod ends do I need just 4 total right 2 of each? I'll PM you my adress, just let me know what I owe you and I'll be sure to post pictures up Im so excited to get it going. Debating on how to strip frame, have access to a sandblaster but I also think these little '' gasket strippers " that mechanics use ( look like brillo pad grinding wheels ) would work just fine? Im going to put all new bolts on it, I dont think anything is threaded into frame should be good to nut and bolt everything. Also what do you guys use for throttle/brake linkage? I think whats on this is to thin looks like it will bend.cryo-tek wrote:Hi TrackerTed,
I’ll have some front end parts finished for you next week. I’m making you some idler arms, a center link, tie rods, spacers, and a drag link. You’ll need to get some new rod ends for the parts. You can get them from McMaster Carr. (http://www.mcmaster.com/ )
Here’re the parts number for the ones like what’s on the truck now.
10-32 Right hand thread, 60645K111 and 10-32 Left hand thread, 60645K112
I’ve been using what I think is a step above the stock ones. The part number for those is
10-32 Right hand thread, 2458K111 and 10-32 Left hand thread, 2458K112
I have a pile of the left hand nuts for the rod ends so I’ll send you some of those with the parts.
They also have the bottles that are used for the gas tank for under $3.00. The part number for the 8oz bottle is 4293T77. It measures 2” x 3” x 4 5/8”.
Check out the nuts and bolts, they have a great selection.
The only requirement is that you post pictures of your progress.
