Looking for 50cc engines and larger engines
I have searched high and low on ebay with no luck . Im in need of a drag car engine. Looking for 50cc or larger. Looking for something that is already set up to fit in some kind of car (not looking to have to mill off chunks of aluminum), but i will if needed. Let me know what you have. Thanks, Roger.
Re: Looking for 50cc engines and larger engines
See the following post. These engines out of chainsaws dont require any machining to them as the blocks are seperate from the saw casing. But you will need a clutch housing and pull start.
http://www.quarterscalelegends.com/bb/v ... f=3&t=2240
If you can sacrifice a few CC. These engines are VERY good and come with everything ready to go.
http://www.davesmotors.com/s.nl/c.88503 ... id.4506/.f
