skellenger axle tube
Posted: September 25th, 2009, 7:48 am
by Turbogolf
The skellenger axle tube on my recently acquired WCM is pretty short and the rear wheels do not fill the wheel walls. I want to replace with a longer one if that's possible. My question is, where can I find a axle tube of a longer length? I k now the diameter is 1/2" and a tube 14 to 15 inch long would work better. Are these aluminum rods or steel rods or something else? Thanks in advance.
Re: skellenger axle tube
Posted: September 25th, 2009, 8:34 am
by minimax-n2
I use 1/2'' titanium in my cars now, from titanium joe in canada
Posted: September 25th, 2009, 8:38 am
You can pretty much use any 1/2 stock. Aluminum, chromolly, titanium, whatever. The best is centerless ground stock, but standard stock will work too. You may just have a tighter fit in the bearings.
Posted: September 25th, 2009, 9:01 am
by Turbogolf
cool! Thanks guys!
Posted: September 26th, 2009, 7:20 am
by stoneyberk
You could also just use standard 1/2'' seamed tube, Then grind down the seam at the end where the bearing rest.. That;s what i did on my rear end housing tubes
Posted: October 9th, 2009, 5:46 pm
by Turbogolf
Got my shipment of alloy rods from onlinemetals.com yesterday and finally decided to use the 7075-T651 rod as the axle tube. I had to sand just a tad off the entire rod to get everything to fit properly. But with a tensile strength of 83,000 psi, it's almost twice that of 6061-T6. But then again, this axle would most likely be in a shelf-queen, so those numbers are just that, numbers.
Posted: October 12th, 2009, 8:15 am
by oldschoolmidget
Hello Mike,
You were saying that centerless ground stock is the best. Where can I buy and what cost would I expect for a 1/2" x 12" long shaft?
Thanks, Oldschoolmidget
Posted: October 12th, 2009, 8:40 am
try these guys and report back the results...
http://www.houstoncenterless.com/
Using regular stock can really suck. Especially when you go into the side covers with the bearings. You usually need to hammer things together. With centerless you wont need to do that. they will fit very nice.
Posted: October 13th, 2009, 4:09 pm
by oldschoolmidget
Hello Mike,
I called and talked to Kelly. Centerless is the best, but there was a minimum charge of $100. So I'm going to Mcmaster-carr. Case hardened steel with all the same tolerances costs about $6.50 for one 1/2' x 12" shaft.
Oldschoolmidget
Posted: October 13th, 2009, 4:11 pm
good tip, did not know it was the same. Sounds like a great price too. let us know how it works.
Posted: October 20th, 2009, 2:11 pm
by oldschoolmidget
Hello Boy's,
I got my axle shift the other day from Mcmaster-carr and it's very nice. Hardened steel to .030" deep. It fit like a glove, no problems. very nice shine came in a plastic wrap with a plastic protective sleeve. At about $6.50 plus shipping.
Oldschoolmidget
Posted: October 20th, 2009, 2:16 pm
moved to tips and tricks! Good tip!!
