3D body gurus
Posted: December 16th, 2015, 3:11 am
by Vcut670
Question to anyone experienced with 3d cad , for car bodies.
is it possible to use a 1/18th scale diecast model and have it scanned in 3d , then have that scan up sized to 1/4 scale , then programmed to the cnc to cut? Or do I have to use a 3d Drawing , I am only learning how this all works .
Re: 3D body gurus
Posted: December 17th, 2015, 12:30 pm
by eightman
sure this can be done... but
- as you want to scale up the accuraty of scan should be high
- you can't, or it's hard to modify the shape before CNC mill or print
- you can "draw" a new geometry on the scanned mesh made from digized dots, so you can modify the shape and have better quality model, it take a lot of time, some expensive programs can make it for you nearly automatic
today you can find a lot of 3d models of cars, and when available it's easyer to start working with these models and turn them into the shape you want.
hope this help
Re: 3D body gurus
Posted: December 17th, 2015, 5:28 pm
by Vcut670
Thanks for that info , I am just trying to find the easiest or best way to get a 3d cad of my favourite car design for a cnc plug.Most companies I ask to help me just do house drafting only, so I keep looking.
Re: 3D body gurus
Posted: December 19th, 2015, 6:43 pm
by Vcut670
Eightman ,I have found a site who sells 3d cad of hundreds of different cars,,but they have a lot of different formats eg: DXF ,STL and a lot of others ,which is the best format to convert to G-Code for the CNC machining,
