Page 1 of 2
Raco GN to Stadium truck conversion.
Posted: February 22nd, 2013, 1:46 pm
by PTModIT
The last Raco GN I bought I made into a Stadium truck.I made the front kick up bumper .The aluminum rear swing arms came with some extra parts from a Jac-Rabbit. Then added Jac-Rabbit Shocks. Just a new paint job and some taller wheels and it's ready to go.
Re: Raco GN to Stadium truck conversion.
Posted: March 20th, 2013, 11:32 am
by PTModIT
New tires installed.Now I'm waiting for some warm weather to paint the body.
Posted: March 20th, 2013, 11:54 am
by Lovedr
PTModIT:
can you tell me where you got the aluminum rims and tires? I have a new era truck that i want to get some nice wheels for.
thanks
Posted: March 20th, 2013, 4:19 pm
by PTModIT
Hi, The rims are for a Raco.They came in a parts lot that I bought.If you have a lawnmower ,snowblower repair shop near you they should be able to order them .The size is 9x3.50-4 .Just to warn you, the rims are not a perfect fit ,meaning there is side to side play of the rim and tire bead. Which means the tire will not inflate centered on the rim.I was going to have a machine shop press fit a aluminum ring to take up the space and center the tire.But it was going to cost too much.So I just used fiberglass packing tape and wrapped it around the rim and built up layers to get a snug fit.The tires aired up perfectly.
Posted: March 20th, 2013, 8:39 pm
by Lovedr
PTModIT
Thanks for the info. I know where to buy the tires but not the rims. Are you saying that a local small engine shop will know where to get these rims? I know they can about the tires but not sure about the rims
Posted: March 21st, 2013, 4:34 am
by PTModIT
No, They can't get the rims.You will have to ask in the WTB section.
Posted: March 21st, 2013, 8:43 am
by PTModIT
Do you have the 6 hole hubs?
Posted: March 21st, 2013, 10:12 am
by Lovedr
yes, I think so. its a new era and I think they made all there wheels with 6 holes.
Posted: March 21st, 2013, 11:27 am
by PTModIT
I think I might have some older WCM 6 hole rims.I wonder if the are the same size bolt pattern?And they won't be perfect.I can take a look.But no guarantees.
Posted: March 21st, 2013, 11:40 am
by Lovedr
PTModIT:
that would be great. I would like 6 wheels total if you have them. do you think I need 3 or 4 inch?
again,
thanks for your help
Posted: March 21st, 2013, 12:25 pm
by PTModIT
This is what I have.4 complete rims.They are 3".That's the size for those tires.Look at the pics.The 1" halves have the scrapes on the rim bead.The one rim laying on it's side is glues together and the 1" half has a small valve glued in .So that extra half is if you don't want that little hole in the rim when the valve is removed.3 of the 2" halves are in good shape.The other one has a ding .Also the rims have the 6 holes and the 4 holes in them except for one of the 1" halves.They need some TLC .The rim that looks dirty is the one that is glued.We did that to put air in them, hence the little valve stem.
Posted: March 21st, 2013, 1:17 pm
by Lovedr
PTModIT
PM sent
Posted: March 23rd, 2013, 5:54 am
by PTModIT
I might ,But this thing is heavy enough.
Posted: April 15th, 2013, 1:42 pm
by PTModIT
New paint scheme from 1992.Dodge stadium truck.Just need some decals.
Posted: April 15th, 2013, 3:34 pm
by PTModIT
