Pacesetter Clutch help
Posted: May 27th, 2012, 5:45 am
by PaulSongas
Hey guys.. Need some help.
Below are 2 clutches. One from a chain drive car (right), one from an inline set up with silver dollar rear end. (left)
Other side
My question is... The silver dollar clutch has nothing to keep it from sliding forward off the holder on one side. This is how I got the car, and I wasn't so sure about it. I put it together that way, and it slid the clutch off the mount towards the motor when I spun it over. Am I missing a piece, or need something else???? See pic below to get a better idea.
Re: Pacesetter Clutch help
Posted: May 27th, 2012, 4:19 pm
by PaulSongas
vwguru75 wrote:The one that slid off is to be installed inside a clutch drum like on a chain drive. It can't walk out because the clutch drum with sprocket backs it. The other part, as you have it mounted, stops it from walking OUT of the drum.
Try and blow this up to see what I'm talking about.
The one on the right in your picture looks like it should work for your application, the one on the left POSSIBLY could be flipped to not be able walk the shaft but instead walk towards the inside of the clutch bell.
I think that is what I am going to do, thanks.
Posted: May 31st, 2012, 6:24 pm
by PaulSongas
Flipping it will not work.. The thread depth changes, so to get the clutch lined up, the motor mount holes are off. :x
Someone with this car must have an answer!
Posted: May 31st, 2012, 9:06 pm
paul, i just went through all my bins. All left hand threaded ones are constructed like that. All the right hand threaded ones are constructed like your other one. So this looks correct. Now what i am wondering is if maybe the wrong engine is in there?
Posted: June 1st, 2012, 5:14 am
by PaulSongas
Could be a different engine... Although zoomie headers are a direct fit, and everything else fits fine. I just need to come up with a stopper for the back side of the clutch and I'll be ok. :mrgreen:
Thanks guys
Posted: June 1st, 2012, 5:22 am
by QAman
Paul, how about a fender washer. I/ve seen them up to 3 inch in diameter. You just need to get one with a small enough hole to be threaded.
Posted: June 1st, 2012, 5:30 am
Is the engine the correct rotation for the rear?
Posted: June 1st, 2012, 6:09 am
by PaulSongas
QSL wrote:Is the engine the correct rotation for the rear?
I'm pretty sure it is.. The one way bearing in the pulley to start it will only let it turn over the direction the tires need to go forward.
Posted: June 1st, 2012, 7:10 am
by PaulSongas
QAman wrote:Paul, how about a fender washer. I/ve seen them up to 3 inch in diameter. You just need to get one with a small enough hole to be threaded.
That's what I was thinking, or worse case drill and tap the base with a couple holes to mount a fender washer.
Posted: June 1st, 2012, 2:35 pm
by PaulSongas
I did get an e-mail that I am missing a facotry part, pics to come
Posted: June 1st, 2012, 6:10 pm
by PaulSongas
I found what I am missing thanks to some member help. I am missing a special washer/insert. Mike or anyone else got one laying around?? :mrgreen:
Posted: June 1st, 2012, 8:27 pm
looked in whats left in the garage and i dont see those. Sorry, wish i had them there. Would send you one. All my clutches are just like yours too.
Posted: June 2nd, 2012, 3:43 am
by PaulSongas
Thanks for taking a look Mike. :mrgreen:
Posted: June 4th, 2012, 9:04 am
by PaulSongas
Wow.. Might be on to something here. Thanks to Larry, it looks like he found the source for the clutches. Looks like they were originally made by Husqvarna, and a company called Poulan.
The stuff looks to be still available through Poulan, fingers crossed my order will be "in stock"!
Posted: June 15th, 2012, 5:42 am
by PaulSongas
Tracking shows the washer should be here tonight. :mrgreen:
