dragster - "Frankenstine"
Posted: May 24th, 2012, 2:39 pm
by QAman
I'm going to call this dragster FRANKENSTINE. It was actually put together once and ran up and down the street. Then it was put on a shelf. I decided to scrap the origanal design and make a new front section with a stonger front axle and steering system and beef up the rear section around the rear end. it is still going to be a mixture of different dragsters of the past. Hence the name. Roger.
Re: dragster - "Frankenstine"
Posted: May 24th, 2012, 4:01 pm
by PaulSongas
Yikes!!!
Posted: May 25th, 2012, 5:51 am
by a187lbird
Looks like modern art to me.
Posted: May 25th, 2012, 8:39 am
by PaulSongas
A couple more cuts and you could have a 1/4 scale diorama of Shirley Muldowneys crash.
Posted: May 25th, 2012, 8:52 am
by PaulSongas
PaulSongas wrote:A couple more cuts and you could have a 1/4 scale diorama of Shirley Muldowneys crash.
Posted: May 25th, 2012, 2:08 pm
by QAman
Ouch! I called Oscor Goldmen and Igor and we all agreed it can go back together and be faster and stronger than before.
Posted: May 26th, 2012, 1:41 pm
by QAman
Brad, this is the same Performance Drag Products daragster i had on Rc Burnout. I got this from Paul a while back. Roger.
Posted: June 25th, 2012, 3:36 pm
by QAman
Well, I guess you can call it a roller again. I finally got time to get the rail back in one piece. New front tube section. Pacesetter style steering with adjustable turnbuckle, and a couple crossmembers and a stronger wing support in the rear. Still working on the body and a different brake/throttle setup. Roger.
Posted: June 25th, 2012, 5:17 pm
by PaulSongas
Looks real nice.
Posted: June 25th, 2012, 6:32 pm
by QAman
Paul, thanks for your help on the front axle assembly. Pictures do beat a thousand words. Roger.
