Just a question.
Posted: July 1st, 2011, 11:28 am
by PTModIT
Hi, Could someone tell me which fuel line from the Raco fuel tank is the main feed line to the carb.I can't see inside.Thanks.
Re: Just a question.
Posted: July 1st, 2011, 11:59 am
by Venomusss
PTModIT wrote:Hi, Could someone tell me which fuel line from the Raco fuel tank is the main feed line to the carb.I can't see inside.Thanks.
It will be the line with the heavy filter flopping around inside the tank. On most Jac-Rabbits it is the line closest to the engine. But I have seen the filter installed through both holes on the Gas Tank. Hold the tank up to a light so you can see through the tank and you will see which line has the filter.
Posted: July 1st, 2011, 12:03 pm
by PTModIT
Thank you.I didn't even think to use a light.
