WCM IROC Camaro project.
Re: WCM IROC Camaro project.
Oh I like this! This front end looks 5000 times better than the last one. And is that the fuel tank in the back of the bench of photo 1?
Also if you wanted to add something "extra" I purchased one of these on ebay a few weeks ago for $14 and they look very nice and pretty close to scale.
Just search "PC radiator" you will find it.
Here is the item number: 170900712317
Dimensions are: 158mm x 120mm x 30mm or roughly 6 7/32 inch x 4 23/32 inch x 1 3/16 inch
Tube Diameter: 9.5MM or roughly 3/8 inch
Yeah DTW is right you can find a lot of different sizes. I went with that size because it fits both my GN and super mod and looked scale, and by the looks of your front end I do not think you will have a problem with space so you can go big.
I had seen a very narrow cooler once but cannot find it any more if anyone could help that would be awesome, it was roughly 120mm x 60mm x 40mm and had some pretty large diameter water ports.
Funky if you want one of the coolers I have one with a fan that you can have. I was going to use it on my electric fuel altered but to have enough volume of water for it to cool you need a surplus tank. If your interested just pay the shipping and its yours. Geoff
The front end looks much better. Great project.
personally, I like what you already have.
that's the way I like my ladies. lol.
Looks good Funky!
I have no clue what your talking about. Here's the HOT ROD Magazine spot featuring my Pro Stock car.
HOT ROD Magazine featured Gary Conley's Pro Stocker and V8 engine, so mine was certainly not the first. Jus' Keepin' it real.
Keep up the good work. You certainly live up to your name.
Forgot that I had the water pump for that radiator and just put it on flea bay, did not jog my memory till just now reading this.
OHHH yeah that looks "SMOOTH" !!!
If you can pull off running the tires that tucked in under the body with no rubbing that would look absolutely amazing.
