Chain size for Yankee Concepts F1
rs4pilot
Post by rs4pilot »
Currently in the process of restoring an old Yankee F1 car. The issue I've run into is finding the correct chain size that meshes with the rear sprocket. I've tried #25, which the pitch is too short, #35, again too short and too wide and a finally a single speed bicycle chain which the pitch was too long.
Does anyone have an idea of what the correct size is? Curious as to what other Yankee fellow owners are running pertaining to the chain size. Thanks
Re: Chain size for Yankee Concepts F1
Contact Yankee Shop in France. They're very good at responding.
rs4pilot
Post by rs4pilot »
Kaye wrote:Contact Yankee Shop in France. They're very good at responding.
Thanks, I've emailed Laurent @ Yankee earlier, figured I'd ask here while I wait for a response from him.
Slowly making progress on this restoration
rs4pilot
Post by rs4pilot »
Thank you. I Should have known the chain required is metric.
Response from Laurent confirming this as well.
“Hello ,
The chains for our models are all in the step of 8mm
Formula 1 has 61 links
regard
Laurent”
anytimerc
Post by anytimerc »
8 mm metric pitch chain is the same as 25 pitch US. It is just longer and wider.. I'm supersized you had or found or had US chain over there. A roll is around $20 US here. :D
laurent
Post by laurent »
You can find with EBay :
British Standard 05B-1 8mm Pitch Simplex Roller Chain
UK is the best choice for this part
