offset modified
offset modified
Here's a 1/10 scale offset modified I'm building using the kendrick template. (Midnight pumpkin running gear).
Re: offset modified
It will have a parma hemi made to look like a big block found on the full size supers. It will have torsion bar rear and coil over front suspension.
Re: offset modified
Very Nice. What size rod are you using?
Re: offset modified
Nice one wish the new admin would make the changes so we can see these on QSS
Re: offset modified
Thanks, I'm using 1/8 inch music wire.
Re: offset modified
cool project. Looks great so far!!!
Re: offset modified
Love love love it!! Big are you brazing? I've never brazed, need to start learning.
Re: offset modified
This one is just soldered. It makes a very strong joint. It on hold right now with everything else. Im having work done on my new shop and had to pile everything in the middle of the floor...
Re: offset modified
What kind of solder can I use for metal tubing, is it even possible?
Re: offset modified
it will work for this type of project. Ive built a few clodbuster frames like this and they hold up pretty good. Its best to use a torch and a brazing rod but silver solder works fine.
